Activity Forums DaVinci Resolve No 29.97 Rendering?!
  • No 29.97 Rendering?!
    Posted by Jesse Glucksman on May 10, 2012 at 4:06 am
    Here’s a dumb question, but I’m new with Resolve so I promise it’ll be the last time I ask it. I got a project that was in 29.97, but Resolve refused to let me render in anything other than 23.98 or 24. Obviously, kind of an issue (though I did end up rendering in 24 then using Apple Cinema Tools to reconform in 29.97, so I think it’ll be okay).
    What did I do wrong? I use the Decklink SDI card–is it possible that since it’s the cheapest card it doesn’t play well with 29.97? I’m one paycheck from investing in a better card so this may all be moot anyway.
    -Jesse
    Jesse Glucksman replied 14 years, 4 months ago 4 Members · 6 Replies
  • Juan Salvo
    May 10, 2012 at 4:10 am
    You probably set your session to 24fps.
    Online Editor | Colorist | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Jesse Glucksman
    May 10, 2012 at 4:12 am
    You’re right, I did. I changed it to 29.97 in the config settings, but only after the fact. Does that mean the whole project is kaput?
  • Rohit Gupta
    May 10, 2012 at 5:58 am
    You should not be able to change the conform rate after you have clips in the media pool, and you have sessions created.
    If you have already colored your project, setup a new one, and use color trace to copy grades across, or use the gallery stills.
  • Joseph Owens
    May 11, 2012 at 1:29 am
    [Jesse Glucksman] ” I changed it to 29.97 in the config settings”
    You’re sure you didn’t just change the display preview settings? That is allowed, and you can add 2:3 pulldown, etc., if you’re working with 23.98 for broadcast.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Jesse Glucksman
    May 11, 2012 at 8:49 pm
    Joseph–I changed the timeline settings, which may have accomplished something but the render window still limited my options to 23.98 and 24. I think, like Rohit implied, once a project is in motion it may not be possible to alter it in the way I needed to in this instance.
    It had been 29.97, I changed it to 24, and needed it back at 29.97. It’s for broadcast in Brazil–I assume 29.97 is their thing, or the filmmaker just chose that for his own reasons. Apple Cinema Tools allowed me to change it to 29.97, and the audio was literally only one frame out of sync. Problem solved for now–better preparation will solve the problem in the future.
  • Jesse Glucksman
    May 11, 2012 at 8:51 pm
    Thank you for that. I hadn’t used the Color Trace function before but will remember for the future (if it’s ever an issue again). Using Apple Cinema Tool was enough for the purposes of this project (low budget, past deadline).
    -Jesse
