Activity Forums Apple Final Cut Pro Legacy No 25Psf capture?
  • No 25Psf capture?
    Posted by Eugene Lehnert on November 23, 2011 at 3:12 pm
    I rarely use 25p material but is there no HD 25Psf capture in Final Cut Pro that isn’t 50i? I had to do a job and I had to reset all my clips manually to progressive dominance in the item settings. I never noticed that before. Is this the only way to work in 25Psf progressive?
    Rafael Amador replied 14 years, 9 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 23, 2011 at 4:24 pm
    [Eugene Lehnert] “I rarely use 25p material but is there no HD 25Psf capture in Final Cut Pro that isn’t 50i? I had to do a job and I had to reset all my clips manually to progressive dominance in the item settings. I never noticed that before. Is this the only way to work in 25Psf progressive?”
    You select all the stuff in the Browser and change it at once.
    rafael
    http://www.nagavideo.com
