Activity Forums VEGAS Pro No 1080 25p option
  • Patrick Cooper
    October 24, 2015 at 9:42 pm
    Oh another thing. I know that you mentioned that the default settings in the templates I selected were suited to playback in specific devices. I have used the HDV 720 25p option many times to play back successfully on a HDTV. Though surely, a HDTV could also play back a 1920 x 1080 25p file? After all, that’s the video standard that’s used in PAL countries like mine. And there was advice given to me on another forum to change 1280 x 720 to 1920 x 1080 – so yea I was just following that advice! Though it didn’t work anyway.
    When I record HD video with my Panasonic G6 camera, I select 1920 x 1080 25p. It just seems really strange to me that with Sony Movie Studio, there is no way to use those same specifications when I render / output video. When I want to play the file back on a HDTV via usb, I can of course output the file as 1280 x 720 25p or 1920 x 1080 50i but neither of those options are going to give me quality as good as the original raw footage. Is it just Sony Movie Studio that is to blame or is it the case that there are no NLE programs out there that can create a 1920 x 1080 25p video file?
  • Russ Froze
    October 25, 2015 at 12:14 am
    [Patrick Cooper] “good to know that it’s okay to use 1440. I did not expect that since 1440 is a lower number than 1920 – I would have expected some of the image area to be cut off. I do vaguely recall somewhere among the templates was a 1440 x 1080 25p template”
    It is odd as you mentioned that 1440 would be a number chosen but it is a trick that engineers have applied. By squishing some pixels during encoding and then restoring them to the original size a file can be drastically reduced. The early HD cameras used this to allow more recording time onto expensive media of the day. Also TV and cable providers need to find a way to reduce bandwidth. This method was employed before mp4 was adopted as a standard.
    [Patrick Cooper] “I hope that particular template produces a file that is compatible with a wide variety of devices.”
    Ok that particular template is used for HDTV or DVD/Blu Ray Authoring. IF you are looking for a cross platform template. look under Either MAinConcept AVC/AAC (.mp4; .avc) or Sony AVC/MVC (mp4; m2ts; avc)
    Russ Froze
  • Rick Hughes
    November 11, 2015 at 5:10 pm
    I have Movie Studio 12 .. and just rendered a whole load of 1920×1080 25fps video it is fully supported.
    1080 50i is what you select and that gives you 2 identical frames, look at the pic attached … it is the 1080 50i template … under frame rate it is set to 25fps.
    In my case I modified bit rate as I only wanted 20Mbps average.
  • Patrick Cooper
    November 17, 2015 at 9:24 am
    Rick, what I wanted was 25p, hence the title of the opening post. P stands for progressive. Yes 50i is 25fps but it is interlaced. That’s fine if you want to put your films on a Blu-Ray disc but for me, I would like to play my films on a modern tv from a connected usb drive and have the very best quality possible (progressive displays the whole picture at once whereas interlaced will give you half a picture at any one time.) Additionally, the film festival that I am submitting my film to next month does not accept Blu-Ray discs. I have discovered a 1440 x 1080 25p template on Sony Movie Studio but it produces a wmv file and the bit rate is shockingly low – I don’t think it would look all that great on a big screen at a festival. And my TV doesn’t recognise the file either. So that template is not a valid option.
    Actually, there is one thing I’m unclear about. With a Blu-Ray disc containing 50i material, is it the Blu-Ray player or the TV that converts the video to progressive? If it is the TV that does the converting, would it do the same with 50i material played from a usb drive?
  • Eric Clinch
    November 17, 2015 at 10:14 am
    Patrick, can you not export as mp4 provided your film festival accepts it. I would expect your TV to also play mp4. In SMS12 either the Main Concept or Sony AVC Internet HD 1080p templates will give you 25p if you alter the framerate from their default NTSC settings.
    As for your last query, with a thumbdrive your TV will deinterlace your 25 frames interlaced into 50 full frames to display. With Blu-ray players it depends on their setting. Most give you the option to choose between 50i or 50p output. The former leaves your TV to deinterlace while with the latter the player does the deinterlacing. At least that is my experience.
    Personally I prefer 50i over 25p. With fast or close sideways movement I find 25p jerky. The ideal is of course 50p
  • Patrick Cooper
    November 17, 2015 at 1:25 pm
    Eric, this film festival does accept MP4. They also accept MOV files as well. Unfortunately, with my copy of Sony Movie Studio Platinum 12, there is no 1080 25p option in the Main Concept or Sony AVC templates. In the Main Concept AVC / AAC templates, there are two 1080p options that I can see (Sony Tablet 1080p and Internet HD 1080p) but they are both 29p – not 25p. And the bit rates are really low too. Sony AVC / MVC does come close with a 1920 x 1080 24p option. Okay, I guess I could stick with 50i. Yea I have heard about the potential jerkiness in 25p footage but I never noticed any when playing video directly from my cameras.
    For this film festival, I could submit a 1080 50i file (looks like I don’t have much choice anyway.) However, I can’t find an MP4 1080 50i template, even within the Main Concept or Sony AVC offerings.
  • George Dean
    November 17, 2015 at 5:44 pm
    Just a thought…..
    Patrick wrote, “They also accept MOV files as well.”
    Will they accept a DNxHD codec in an MOV container? If so, that should provide you 25p of a high quality, which you can render from SMS12P.
    Best Regards…..George
  • Eric Clinch
    November 17, 2015 at 8:12 pm
    Patrick, most of the templates are not set in stone. You can modify them. So in the Framerate drop down box select 25.00 for PAL. It is there as an option. The same for bitrates, they can be altered. Then save your customised template under a new name for future use.
  • Patrick Cooper
    November 17, 2015 at 10:58 pm
    George, I’m not sure if they’ll accept a DNxHD codec and I’m not familiar with that.
    Eric, as I have found out through my experimenting, a lot of the settings in the templates are indeed set in stone. Ive found that I can change very little when I try and customise them. If I recall, I may have had some success in changing the bitrate but if I try and change the frame rate (fps), Sony Movie Studio returns an error and refuses to render the video. That’s with two templates that Ive tried to modify. I guess I could try customising some other templates and see if I have any success with them.
  • Eric Clinch
    November 18, 2015 at 12:28 am
    If you’re source material is PAL 1080 50i you should not have problems exporting as mp4 PAL 1080 25p. I’m puzzled as why it doesn’t work for you.
    As for hitting a stone wall if you alter a Blu-ray or AVCHD template so it falls outside the Blu-ray specs then yes you will encounter a problem.
Page 2 of 3
