Activity Forums DSLR Video Nikon video format
  • Nikon video format
    Posted by Tony Connoly on May 29, 2012 at 7:56 pm
    Does anyone know what video and audio codecs the Nikon D800 uses to store its .Mov files? I had head the video part was h.264, but wasn’t sure if that is true, and would like to know what the audio part is. Thanks!
    Rob Manning replied 14 years, 3 months ago 2 Members · 5 Replies
  • Rob Manning
    May 30, 2012 at 6:37 am
    Hi Tony,
    Noting that the uncompressed video is not mentioned here, AKAIK it’s 4.2.2 into an SSD formatted for ProRes, Avid, CineForm etc.
    From the online specs, https://www.nikonusa.com/pdf/manuals/dslr/D800_EN.pdf
    Metering TTL: exposure metering using main image sensor
    Frame size (pixels) and frame rate:
    • 1,920 × 1,080; 30 p (progressive), 25 p, 24 p
    • 1,280 × 720; 60 p, 50 p, 30 p, 25 p
    Actual frame rates for 60 p, 50 p, 30 p, 25 p, and 24 p are
    59.94, 50, 29.97, 25, and 23.976 fps respectively; options support both ★high and normal image quality
    File format MOV
    Video compression H.264/MPEG-4 Advanced Video Coding
    Audio recording format Linear PCM
    Audio recording device Built-in monaural or external stereo microphone;
    sensitivity adjustable
    Other options Index marking, time-lapse photography
    HTH’s
    Rob
  • Tony Connoly
    May 30, 2012 at 11:33 am
    Thank you for the information.
    It says: “Video compression H.264/MPEG-4 Advanced Video Coding”
    Are H.264 and MPEG-4 the same thing?
    Isn’t it unusual for H.264 to have a .Mov extension?
    I am trying to play the movies in a DLNA server which supports H.264 but not .Mov, so the movies don’t play.
    As an experiment, I changed “.Mov” to “.Mp4” and the movie played but not the audio.
  • Rob Manning
    May 30, 2012 at 2:34 pm
    HI,
    You may need to get the VLC media software/player free from the web, or Quicktime from iJOBS.
    https://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
  • Tony Connoly
    May 30, 2012 at 2:37 pm
    Rob,
    The DLNA server I referred to is a Linksys WiFi Router EA4500 that has a DLNA server built into firmware. It supports H.264 and MPEG but it’s confused by the .mov extension, and by the audio too apparently.
  • Rob Manning
    May 31, 2012 at 3:58 am
    So, the key is to convert the native file to .AVI, save a file as a copy, then re-save it with the .avi extension, see if it opens.
    If not, then download the convertor from VLC, it should allow for another format to be rendered.
