Activity › Forums › Apple Final Cut Pro Legacy › nikon d90 capture limitation
Posted by Mahesh Dood on November 20, 2009 at 4:04 amhi
i have a nikon d90, the HD movie option does not allow me to record more than 5min at a time. is there a way to bypass this problem, since sometimes i need to do longer recordings.what can be done?
mahesh
Rafael Amador replied 16 years ago 4 Members · 4 Replies -
Shane Ross
November 20, 2009 at 4:59 amUH…what does this have to do with FCP? Shouldn’t you be posting this on a Nikon forum?
Shane
Read my blog, Little Frog in High Def -
Arnie Schlissel
November 20, 2009 at 10:05 pm[mahesh dood] ” is there a way to bypass this problem, since sometimes i need to do longer recordings. “
Well, the obvious workaround is to use a different camera…
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Mahesh Dood
September 14, 2010 at 10:25 amhi
in my nikon d90 setings i set the video to 720p, which means the video should record at 1280x720p. after recording video via the USB i copy the video files to my comp, the recorded video is not 720p but 480p. i am unabla to figure out why and what to do to make the camera record in HD?sos, bought this camera only for this reason that it could record HD
thanks
mahesh -
Rafael Amador
September 14, 2010 at 10:54 am[mahesh dood] ” after recording video via the USB i copy the video files to my comp, the recorded video is not 720p but 480p”
You don’t have to “capture video”, but to use the Log & Transfer function.
read the last Shane’s tutorial about Tapeless Workflow.
rafael
