Activity › Forums › DSLR Video › Nikon D7100 problem
  • Nikon D7100 problem
    Posted by Matthew Mantas on September 12, 2014 at 4:09 am
    Heya guys, I’m green as grass and don’t know much about filming. Apart from tutorials from Film Riot and Fenchel & Janisch. I got meself a brand new D7100 and I’m now thinking theres something wrong with the camera itself.
    Here is an example of video shot with this camera. https://vimeo.com/105914575 another vid here https://youtu.be/FiBqrKu4ZvY Image is flat 1/125 f1.8 iso 100 1080i 60fps It’s pretty terrible at day, it’s even worse at night
    What could it be? How You call this distortion or whatever it is? Thanks!!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Steve Sharkey replied 11 years, 12 months ago 2 Members · 1 Reply
  • Steve Sharkey
    September 29, 2014 at 8:57 pm
    Generally speaking, you should leave the shutter speed at 50 when shooting video. You might also find that 400 is more like the D7100’s ‘native’ setting, going higher in low light and lower (or drop an ND filter on) when it’s brighter. Try those and see how you get on. Other than the focus not really following the subject, I’m not sure what distortion you’re referring to. An f-stop around f3.5/f4 should make it easier to keep a moving subject sharp – f1.4 really is very shallow. Are you depending on the camera to auto-focus?
