Activity Forums Apple Final Cut Pro Legacy Nightmare P2 and FCP scenario
  • Nightmare P2 and FCP scenario
    Posted by Sean Roach on September 18, 2009 at 1:50 pm
    I’ve never felt the need to post, because I usually can figure out what I need reading past posts. But so far, I’m still up the creek.
    I was given footage shot on a HVX200, transferred from a P2 card and placed on a LaCie portable drive.
    I have the portable drive and have backed it up on my media drive.
    The files are in their proper directories, and I do have the LASTCLIP.TXT file. I have about 12.5 gigs of footage in the main folder, finder says.
    I got P2CMS and it recognizes the clips, attaches them to the thumbnails, but won’t play the clips in that program. It just plays a black screen when I try to preview. I ingested them, but that didn’t work either, still no preview.
    When I try to import in FCP using Panasonic P2 import, nothing happens. I click on the P2 folder (not the contents folder the main p2 card folder) and the computer thinks for seconds and then doesn’t load any of the clips into FCP. I have tried unchecking the pulldown box as well. nothing
    So I tried dropping in the ingested files, but same problem, nothing is recognized, and it asks me for a translation document.
    I am using an older version of FCP (5.1.4) on a OS 10.5.8 Intel mac with 4gigs of Ram. I was thinking I might need to upgrade to FCP 6 at least, but that doesn’t seem like it would fix my problem since P2CMS is also acting up and I have never had a problem working with P2 footage before.
    Any help would save me from going bald tomorrow.
    Sean
    Sean Roach replied 17 years ago 3 Members · 11 Replies
  • 11 Replies
  • Sean Roach
    September 18, 2009 at 3:02 pm
    I realize this might be better in the HVX section., sorry folks.
    But another note. If I export the footage to a DPX sequence in P2CMS I can see in photoshop that the frames are all there, so the video is somewhere, just can’t figure out how to access it.
  • Shane Ross
    September 18, 2009 at 4:22 pm
    Do you have FX FACTORY installed? Perian?
    Shane
  • Sean Roach
    September 18, 2009 at 4:28 pm
    I don’t have either of those.
    Also, I tried exporting to DPX files using P2CMS, and I have made the individual DPX frames. So I can see the footage, frame by frame, in photoshop… so it is there, somewhere
  • Shane Ross
    September 18, 2009 at 4:44 pm
    No, it’s fine to be here. You got a couple P2 experts here, so we can figure this out.
    My problem is that I don’t use P2CMS, as I find it confusing and pointless. So I can’t help there.
    Hmmm…turn off networking…airport, disconnect from Ethernet if you have that (although this is more of an issue with FCP 6.0.x lately). You installed the P2 drivers, otherwise you wouldn’t be able to see the cards (thinking out loud)…
    Perhaps install FCP again? On top of your current install. It will install any missing components. And it SHOULDN’T mess things up. Well, no, that might get you back to 5.1.0… hmmmm…
    So you open P2 Import (or does 5.1.4 have LOG and TRANSFER? I forget, been too long) and you don’t see the card? You direct FCP to it and it doesn’t load. Man, that sounds like the FX Factory issue…
    I’ll ponder more. And perhaps Jeremy will pop in with more ideas.
    Wait…Did you shoot DVCPRO HD P2, or AVCIntra P2?
    Shane
  • Sean Roach
    September 18, 2009 at 4:47 pm
    I believe the footage is AVCIntra 100 I believe.
  • Shane Ross
    September 18, 2009 at 5:21 pm
    A-HA! I don’t think that AVCIntra support hit FCP 5.1.
    Yup, AVCIntra support is only available in FCP 6.o or 7.0:
    https://www.apple.com/support/releasenotes/en/Final_Cut_Pro_6.0_rn/
    Gotta upgrade.
    Shane
  • Sean Roach
    September 18, 2009 at 5:40 pm
    ah! Guess it’s time to… get with the times.
    But for my own piece of mind, why wouldn’t P2CMS play the clips either?
    sean
  • Shane Ross
    September 18, 2009 at 6:19 pm
    Got me. As I said, I don’t use P2CMS…
    Shane
  • Michael Sacci
    September 19, 2009 at 6:09 pm
    “I believe the footage is AVCIntra 100 I believe.” are you sure? your first post said the footage came from a HVX200, one of the two is wrong. HVX200 only shoots DVCPro or DV codecs.
  • Sean Roach
    September 19, 2009 at 6:26 pm
    That’s what I thought too.
    But, when he handed me the media, I asked him if it was shot on an HVX and he said “yes, and shot full HD AVC Intra 100…” so maybe he has his camera mixed up…
    Either way I just bought FCP 7, so we’ll see if that was the problem.
