NG Audio playback of sequence
Just installed FCP to my MAcBook Pro and have imported some .dv files to cut together. Problem is whenever I view material in source viewer the sound plays back perfectly. However when said shot is cut into canvas and appears on the timeline when ever I playback the sequence there is no sound only a steady beep, although with sound waveforms enabled I can see the sound on the timeline.
Help!
