Activity › Forums › Adobe After Effects › Newton 2 Question: How to work with .PNG files?
  • Newton 2 Question: How to work with .PNG files?
    Posted by Tommy Charles on January 17, 2014 at 12:25 am
    If Newton just can’t do this, fair enough….
    What I’m trying to do is use .Png files I made in Illustrator as the rigid body. When I do this, however, Newton can’t seem to see the artwork..it shows white squares in place of it. Then..when the simulation starts, any .png I’m using ignores gravity or else just flies upward.
    I’ve tried using standard masks first to get the keyframes I need and then pasting them onto my .PNGs, but that doesn’t seem to work.
    Please let me know if I’m not being clear.
    ~Tommy
    Roland R. kahlenberg replied 12 years, 8 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    January 17, 2014 at 8:29 am
    Use a Shape Layer or a Masked Solid as proxies. Then either link the Newton results to the PNG or apply a copy-paste routine. Hmmm, then again, you probably knew that.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Tommy Charles
    January 17, 2014 at 9:54 am
    Thanks Roland!
    Can you tell me how to link the results to the PNG? I tried copy and paste of keyframes but that didn’t work.
    It’s really appreciated.
    January 17, 2014 at 10:09 am
    Hmmmm … it’s a basic copy-paste of keyframes. What exactly are you having issues with? Which part of the copy-paste process is not working? Or is it a case of the result not working as expected.
    FWIW, the proxy that you use should have transform attributes that are identical to the PNG. You use the proxy in Newton. Once you’ve applied the results in Newton, you copy the transform attributes of the proxy onto your PNG file.
    HTH
    RoRK
    AE MoGraph Intensity Workshop – Promo Video
