Activity › Forums › Adobe Premiere Pro › NewTek Tricaster AVIs Crash 2.0
  • NewTek Tricaster AVIs Crash 2.0
    Posted by Sandra Miller on December 21, 2007 at 4:43 pm
    Hello,
    I use Tricaster Pro to record events, and then do post production in Premiere Pro. Premiere Pro and Encore crash with these Tricaster AVIs, and it is really sporadic. I can’t make a movie at times, nor burn to DVD.
    Any solutions?
    Sandra
    Bart Conover replied 18 years, 9 months ago 3 Members · 4 Replies
  • Mike Velte
    December 21, 2007 at 7:08 pm
    Download GSpot…it is free app to analyze codecs and such. Open one of your files in it and reply to this by copy/paste the info in Container and Codec into the reply.
  • Sandra Miller
    December 21, 2007 at 7:51 pm
    Hi Mike,
    Thanks for responding.
    Here’s what is in the container:
    Note: 13.7 GB unneeded bytes at end of file
    Multipart OpenDML AVI (5 parts)
    (177163 frames in first part, -3 frames follow)
    Here is what it said in codec:
    Codec: NT25 Name: Status: Codec(s) are Installed
    Note, I do have the Tricaster Codec installed on my computer so that I can work on the files. With some of the AVIs that Tricaster creates, I have no problems with, but others I do. Whenever Premiere is about to crash, it is easy to spot, because the video starts to “stutter” and the audio is no longer synced up.
  • Mike Velte
    December 21, 2007 at 8:54 pm
    Not sure what that means. If the file is about an hour long, it is probably DV. Here is my DV container;
    File Length Correct
    DV Type 2 AVI
    AVI v1.0
    DV Audio/Video: 396 MB (96.54%)
    AVI Copy of DV Audio: 14.1 MB (3.44%)
    AVI Overhead: 86.8 KB (0.02%)
    I suspect that you will need to convert your clips into Microsoft’s DirectShow Type 2 because Premiere’s API module cant handle that codec well. It should be a fast process and all that will be changed is the wrapper. Check with NewTek web site about a conversion utility.
    Also check my post above about GSpot!
  • Bart Conover
    December 22, 2007 at 6:47 pm
    I edit a few files from Tricaster on PPro CS3 with no problems.
    I did however download and install the Newtek Multi-Codec pack from their site.
    At our church, I have edited on PPRO 1.5 with the same codecs . . . with no problem.
    Hope that helps!
