Activity Forums Adobe After Effects newspaper.. animation
  • newspaper.. animation
    Posted by Aroonz Arunpg on July 10, 2009 at 12:25 pm
    hey all…
    mooooooooooooooh
    i am asked to create a title where we pan across the newspaper and when we stop at a particular point in the newspaper, we show the name technician’s title (eg.. edit : aroonz )…
    its film resolution… so there will b atleast 20-30 stops..
    how can i go about this in ae. since its 2048*872, there mayb memory issues …
    should i go with low resolution jpeg or all the text in the newspaper be AE TEXT ?
    kindly throw some light on this so that i can work with ease..
    thanq in advance
    ……..aroonz ……….
    Erik Waluska replied 17 years, 2 months ago 2 Members · 1 Reply
  • Erik Waluska
    July 10, 2009 at 9:24 pm
    If your image is 2048*872, then I would not expect any real problems with memory unless you have a weak system or a lot of other high resolution layers, etc.. If you have enough RAM then you should be good. If it starts to bog down you can set your comp window to half or quarter resolution while your working and/or turn of background layers you don’t need to see until you’re ready to render.
    Creating the text in AE will not help. In fact, it would probably make things worse.
    If you’re doing these moves in 3D space, and are going from one newspaper or headline to another, then you may want to check out VideoCopilot.net for the free “Sure Target” plug-in and tutorial. It may work well for this project.
    -E
