Activity Forums Avid Media Composer NewsCutter won’t digitize DVCPro material?
  • NewsCutter won’t digitize DVCPro material?
    Posted by Pat Furrie on December 8, 2005 at 5:14 pm
    All of our decks here are Sony DVCam, but once in a while we get Panasonic DVCPro tapes in house. Put the Pro tapes in a DVCam deck, and you get video and audio from the deck — if we just hook it up to a monitor. However, we don’t get any audio or video when we attempt to bring in Pro content via Firewire. We can control the deck and see changing timecode in the Avid, but that’s it. If we try to start recording, it will record black for several seconds, and then pop up an error telling us the the audio and video stopped coming in unexpectedly.
    We’d rather capture this properly through Firewire, and not resort to a global capture through SDI. We’ve had the same experience on more than one of our editors with more than one DVCam deck with more than one source tape.
    Thoughts?
    Pat Furrie
    WESH-TV, Orlando
    Wayne Vollweiler replied 20 years, 9 months ago 2 Members · 3 Replies
  • Wayne Vollweiler
    December 9, 2005 at 8:46 pm
    This might sound funny, but did you try hooking up the analog component outputs and analog audio outputs to the Adrenaline? Something tells me the firewire between formats doesn’t work. Simplest solution.
    Wayne V.
  • Pat Furrie
    December 12, 2005 at 3:23 pm
    [Wayne V.] “This might sound funny, but did you try hooking up the analog component outputs and analog audio outputs to the Adrenaline? Something tells me the firewire between formats doesn’t work. Simplest solution.
    Wayne V.”
    Wayne,
    Yeah, I thought about that, but then thought “Hey, maybe there is something like a setting on the deck or Avid that would allow this.” If so, it would be the actual simplest solution. But I can’t find any authoritative information regarding firewire access in this configuration. I really don’t want to set up all my editors with additional analog cabling for something that seems like it should work with firewire, which is both less comlpicated and keeps the signal digital.
    Pat
  • Wayne Vollweiler
    December 13, 2005 at 5:32 pm
    Normally I would agree, but I believe the difference in the codecs between the 2 formats is the culprit here. I don’t think the Sony deck will process the DVCPro material over the firewire port. You might not have a choice about the additional cabeling. Also, you do gain the TBC controls on the analog input – might save you some color correcting as you go. Lastly, if this is the only piece of analog gear, hardwire it in so all they have to do is change the input in the capture settings.
