Activity Forums Avid Media Composer Newscutter keyboard shortcuts
  • Newscutter keyboard shortcuts
    Posted by Deepmine on August 2, 2005 at 11:30 pm
    I use Premiere Pro at home, but my company has just switched us to Avid NewsCutter at work.
    I’ve got an Avid Express “set-set” in my Premiere keybaord set-up, but there seem to be some slight differences between the shorts for NewCutter and Express. “Lift” and “Extract”, for example. I’ve not been able to find anything on this topic on google.
    Is there any difference? Given my lously memory for keyboard short-cuts, I’d like to have everything as close as possible.
    Thanks.
    Nick Brenner replied 21 years ago 2 Members · 1 Reply
  • Nick Brenner
    August 31, 2005 at 6:40 am
    Yep I couldn’t find it either thus I remapped my keys to how i liked them. First in your project bin select settings then click on keyboard then go up to the pull down menus top of your screen and select Command palette then select edit and map your commands by dragging them onto your keyboard to the place you are familiar with. That’s what I did. I also remapped the Matchframe to M on keyboard and keyframse to N.
    cheers nick
