Activity Forums VEGAS Pro Newly installed Vegas Pro 9 won’t reload project
  • Newly installed Vegas Pro 9 won’t reload project
    Posted by Don Smith on July 21, 2010 at 7:57 pm
    So I finally upgraded to Pro 9 from Pro 8 so I could deal with those iPhone 4 video files and other iFiles that Pro 8 didn’t like. I got almost finished with a project, then when I tried to work on it again it would not load up properly. I have the message:
    An error occured when loading a plug-in or plug-ins. The plugs specified are not installed on this system:
    Plug-in: ‘Sony Track Noise Gate’ failed to load. Please make sure the plug-in is properly installed.
    Plug-in: ‘Sony Track EQ’ failed to load. Please make sure the plug-in is properly installed.
    Plug-in: ‘Sony Track Compressor’ failed to load. Please make sure the plug-in is properly installed.
    So I uninstalled and then re-installed hoping that would solve the problem, but the same message appears and I can’t continue to work on the project.
    Any ideas on what I can to to fix this??? Why could I have gotten as far as I did and then have this problem??
    Dave Lozinski replied 15 years, 9 months ago 2 Members · 1 Reply
  • Dave Lozinski
    July 26, 2010 at 2:33 am
    When you uninstalled were you able to verify that everything had indeed been uninstalled? EG, nothing left under C:\program files\sony …. ???
    Just because a program uninstalls doesn’t mean it removes everything unfortunately.
    https://www.davelozinski.com
