Activity Forums Media 100 newer version Media 100 message
  • newer version Media 100 message
    Posted by Jay Ryscki on June 12, 2007 at 12:36 am
    I had two Maxtor drives that had the same volume creation date. This was causing confusion for Media 100, so I backed up the material off of one of the Maxtor’s onto a third drive and reformated the Maxtor. Then I moved the media back onto the Maxtor. Now, whenever I try and play this footage I get the following message:
    “Could not play because the media was recorded with a newer version of Media 100i. Stopped at blah, blah, blah…”
    Folks this is A LOT of footage, it would take days to redigitze…
    Has anyone gotten this message before, anyone have any ideas for a work around.
    FYI audio clips seem to be unaffected, haven’t come across any audio tracks that had a problem playing back yet, it’s just the video media and it’s just the stuff that got moved (backed up) off of the Maxtor…
    2nd FYI, I tried disconnecting the problem Maxtor drive and re-connected the third drive where I had backed the media up to. I get the same problem.
    thanks in advance for your advice.
    Accountneedsrealnameupdate replied 19 years, 3 months ago 3 Members · 2 Replies
  • Abercrombie Pupputnick
    June 13, 2007 at 8:01 pm
    The newer version complaint typically comes from drives that aren’t fast enough to play your media. Make sure you didn’t format the volume with journaling turned on.
  • Accountneedsrealnameupdate
    June 14, 2007 at 2:01 pm
    Yeah, what he said. Test the theory by moving just a couple of files to your MacHD and see if they work from there.
