Activity Forums Avid Media Composer Newby question….Capturing with Scene Detection…
  • Newby question….Capturing with Scene Detection…
    Posted by Marcelo Lewin on October 23, 2005 at 8:36 am
    Hi everyone!
    I’m new to Avid Xpress Pro HD 5.2. I’m trying to capture my footage (from a Sony TRV-38). It seems like it’s only capturing the entire clip with out any breaks (in Adobe Premiere Pro I can just select “scene detection” and it will break the files into clips when it detects a change in the time code).
    Anyhow…I found under “Capture Settings–>DV Options” a setting called “DV Scene Extraction” with “Add Locators” selected by default. I also see a “Create Subclips” selection. The problem is that I can’t select any of the selections under “DV Scene Extraction”. It’s grayed out. Is there some other setting affecting this setting?
    Any help would be greatly appreciate it.
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
    Marcelo Lewin replied 20 years, 11 months ago 2 Members · 2 Replies
  • Michael Phillips
    October 23, 2005 at 2:30 pm
    Once you are done capturing, select all the clips in the bin before selecting “scene detection”. It only does the processing on already captured clips as a very fast post process rather than during the capture process.
    Michael
  • Marcelo Lewin
    October 23, 2005 at 6:15 pm
    Yup. I finally figured that out after I posted this (around 3am!!!!). Thank you though!
    Marcelo Lewin
