Activity Forums Maxon Cinema 4D Newby Question
  • Newby Question
    Posted by Karim Daire on May 10, 2007 at 11:51 am
    Hello,
    I am rather new to C4D and working with 8.5 at the moment. I got a small problem I can’t grip.
    I used a cylinder, turned it into a polygon object and made some changes. Now I want to rotate it around its center axis and animate it which works OK but as soon as I rotate it by 10 degrees on another axis and animate the center axis for rotation the object tumbles.
    I cant’t find the problem on this although I am pretty sure its a one-click thing. Any hints??
    Karim
    Davesink replied 19 years, 4 months ago 2 Members · 1 Reply
  • Davesink
    May 10, 2007 at 3:39 pm
    I don’t know about a “one-click” solution, but let’s say you want a spinning globe. What I’d do is animate the untilted sphere (or other object) on its y axis, then place that into a null. You can then rotate or tilt the null object. Your globe (or Cylinder should now roate properly.
