Activity Forums VEGAS Pro NewBlue FX Vegas 9 64bit
  • NewBlue FX Vegas 9 64bit
    Posted by Damian Smith on February 20, 2010 at 3:19 pm
    How do I install NewBlue FX in Vegas 9.0 64bit? When I install NewBlue, Vegas doesn’t recognize the plug-ins…they dont show up in the transitions.
    Can someone please help?
    Edward Troxel replied 16 years, 4 months ago 4 Members · 6 Replies
  • John Rofrano
    February 20, 2010 at 3:40 pm
    When you install the NewBlue plug-ins you specifically have to select 64-bit Vegas during the installation. If you have both 32-bit and 64-bit Vegas you have to run the installer twice (once for each).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Ebbelaar
    March 22, 2010 at 8:23 pm
    I have sony vegas pro 9 64-bit. I installed Newblue fx motion effects 64-bits but it doesn’t show op in vegas. i also tried installing both 32 and 64-bits versions of Newblue fx motion effects like you said in the comment but nothing works.
    How can i get it to appear in sony vegas?
  • John Rofrano
    March 23, 2010 at 12:11 am
    That should have done it. I would follow up with NewBlue technical support. They work for me.
    ~jr
  • Dave Ebbelaar
    March 23, 2010 at 4:33 pm
    Oke thank you. i’ll try that
  • Dave Ebbelaar
    May 7, 2010 at 12:34 pm
    Have you found a solution yet?
  • Edward Troxel
    May 7, 2010 at 3:32 pm
    Dave, make sure you download the most current version from here:
    https://www.newbluefx.com/downloads.html
    During installation, make sure you pick “Sony Vegas 64-bit”. Once installed, they will be available on the VideoFX or Transitions tab depending on which package you install.
    Edward Troxel
    JETDV Scripts
