Activity Forums Boris FX Particle Illusion Newbie would appreciate some help
  • Newbie would appreciate some help
    Posted by Beast666 on September 9, 2006 at 9:47 pm
    Hello all,
    I am a newbie. Recently saw some example AVI footage of Particle Illusion, where a guy was waving a stick around ( like a magic wand ). As he waved the stick around, sparklers emitted from the tip of the stick. So my question is based around, how do you make emitters ” follow ” part of an object, as the object moves around on the background footage ???
    For example, if I filmed myself holding something, and waving it around, and then used that footage as a background, how could I apply emitters to whatever I am holding ( or waving around ) ??
    If anyone can help, it would MAKE MY DAY !!
    Humbly, in appreciation.
    Beast666 replied 20 years ago 3 Members · 5 Replies
  • Bill Hamell
    September 9, 2006 at 11:37 pm
    One way is to key frame it.
    Load your AVI as the background and avance to the first frame the effect starts, place your emitter there. Then advance a few frames and move your emitter to the new location.
    A new key frame is set, repest this untill the movmemt and effect end.
    Go back to frame one play and adjust as needed.
    Bill
  • Beast666
    September 10, 2006 at 3:14 am
    Thank you so much, Bill. You are a gentleman for helping me out. Seems to me, I should be placing the emitter every time the position of the object moves ( noticeably ) ??
  • Bill Hamell
    September 10, 2006 at 4:23 am
    [beast666] “Seems to me, I should be placing the emitter every time the position of the object moves ( noticeably ) ??”
    That seems correct to me. 🙂
    You can use as many or as few key frames as you need.
    Bill
  • Alan Lorence
    September 10, 2006 at 2:29 pm
    Make sure you’re in “Select” mode (mouse cursor looks like an arrow in the stage) instead of “Add” mode (mouse cursor looks like a little circle).
    There’s a toolbar button for this, or just use the “A” keyboard shortcut.
    Alan.
    wondertouch
  • Beast666
    September 10, 2006 at 8:27 pm
    Thanks Alan, I will remember this. Gonna buy your Super Emitters Collection today. Am hoping to have some fun with them.
    Humble regards.
