Activity Forums Adobe After Effects Newbie Workflow Question….Help Out?
  • Newbie Workflow Question….Help Out?
    Posted by Tony Brittan on August 14, 2009 at 12:56 pm
    Thanks in advance! I’ve been working in FCP for years and finally decided to take the leap to CS4 to add After Effects to my arsenal.
    My question is about workflow. Most of my work (commercials, TV episodes, etc) deals with Apple ProRes (non-HQ) 1080i60 footage and timelines in FCP. So what would my ideal project / comp settings be in AE to make them ready to roll in my FCP projects. Also, will I be able use my ProRes footage in AE comps / projects (ie does AE play nice with ProRes)?
    Using Mac Pro Octo Core (late 2008), 8gigs ram, tons of hard drives (internal / external with eSATA raids as well), Matrox MXO2, FCP 6.0.6, Adobe Production Premium CS4
    Tony Brittan
    Apple Certified Pro – FCP
    islandshoreproductions.com
    Robert Craghead replied 17 years, 1 month ago 2 Members · 3 Replies
  • Robert Craghead
    August 14, 2009 at 8:53 pm
    From my experience, with After Effects its all about the export. In AE, we usually create all projects in 1080p comp size for future considerations, and export to the appropriate codec for editing in FCP.
    In A DVCProHD1080i FCP sequence we would render in that codec from AE. Compressing the file, though, sometimes does weird stuff. In this case we render out to a less compressed format (animation, None), although these are much larger in size.
    In the end what looks good is what you should use.
    Hope this helps.
    Robert Craghead
    Founder
    Ten Stories
    2775 Kurtz Street, Suite2/3
    San Diego, CA 92110
    T: 619.295.5650 x101 F: 619.295.4838
    rob@tenstories.com
    http://www.tenstories.com
  • Tony Brittan
    August 15, 2009 at 1:35 pm
    Thanks Rob! Much appreciated. So…does ProRes work in AE? This us some very cool stuff. I’m excited to dig in once I finish my current project in FCP.
    By the way…I’m from San Diego 🙂 Grew up in Penasquitos and Poway. Good times!
    Tony Brittan
  • Robert Craghead
    August 15, 2009 at 7:35 pm
    Nice. It’s perfect weather in SD right now.
    Prores will work in AE. It’s a QuickTime component so will work in any QuickTime component software. Will have to check on the export settings in AE, but I think they will render to as well.
    When rendering, may want to choose export (instead of render) and look through the codec options for the one you want.
    Rob
