Activity › Forums › Apple Final Cut Pro Legacy › Newbie: what size monitor to use
  • Newbie: what size monitor to use
    Posted by Kmaultsby on December 28, 2005 at 6:42 am
    I am about to purchase my new G5 2.0GHz unit for everyday use and video editing with FCP. I have not picked out monitors. Is it best to use two monitors like two 17″ or 19″ monitors or one larger wide screen monitor. When I was editing with LE 5.5 I was just using one 19″ monitor. But with FCP will I need more room?
    Kevin Monahan replied 20 years, 8 months ago 4 Members · 3 Replies
  • Gunleik Groven
    December 28, 2005 at 4:13 pm
    You don’t need two monitors, but it’s very comfortable and handy!
    You should consider an external broadcast monitor or at least a TV for viewing your cuts in. You couleither use your deck/camera as a D/A converter or use something like the Canopus ADVC 110
    Gunleik
  • Enzo Tedeschi
    December 29, 2005 at 5:35 am
    Personally, I find one widescreen monitor for the Mac OK for FCP. One of those and a smaller, say 17″ just to use for bins etc is ideal. If you plan on FCP using 4:3 monitors for the Mac, I certainly recommend two of them, or you’ll get cramped real quick.
    And to echo Gunleik’s comments, consider an external video monitor for your vision. It’s a must wether your Mac has one screen or ten!
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Kevin Monahan
    January 5, 2006 at 9:13 pm
    Yes, you’ll certainly need a TV or broadcast monitor if you can afford one.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
