Activity Forums Zaxwerks Newbie to INVIG.
  • Newbie to INVIG.
    Posted by Crjoe on April 29, 2005 at 8:56 pm
    I have tried, and unfortunately I don’t know much about Invigorator or Illustrator, but how do I get a Illustrator text file with vectors so that I can import them into Invigorator. I have tried saving the files as AI8 files but Invigorator still says they are not valid files.
    Any help would be appreciated.
    Crjoe
    Glenn Moore replied 21 years, 4 months ago 2 Members · 3 Replies
  • Glenn Moore
    April 29, 2005 at 10:00 pm
    You first must Convert the AI file to Outlines. Select the text (or shape) then go to ‘Type’ in the toolbar and then Convert to Outlines. Save the file as a an AI file. In Invig, select the option you want (Open an Illustrator File). A pop up window will open. You point to the file and it will be transferred and converted from Outlines to a 3D object. You don’t manually bring the file in. Let the program find it and import it. From there, it’s all you. Tweak away. I hope that helps and is clear enough.
  • Crjoe
    April 30, 2005 at 3:44 am
    Thanks for the help. I couldn’t figure that out.
    This is great.
    crJoe
  • Glenn Moore
    April 30, 2005 at 4:16 am
    Glad you got it to work. It is a very cool app. You may want to scan the book and browse some of the tutorials. I dont use it for everything but I can always find some use for it in my projects.
