Activity Forums Maxon Cinema 4D Newbie: simple extrude
  • Newbie: simple extrude
    Posted by Kurt Murphy on February 13, 2007 at 3:17 pm
    Trying to create a simple ring around a globe. I used the disc object and created a disc, used the inner radius to make a ring. I make the object editable (C) and select an Extrude Nurbs. I drag the disc onto the Extrude Nurbs, but nothing happens when I exrude any of the Movement paramters … it stays flat. What am I missing?
    thanks,
    kurt murphy
    Kurt Murphy replied 19 years, 7 months ago 3 Members · 4 Replies
  • Mylenium
    February 13, 2007 at 4:22 pm
    The so-called “NURBS” objects only work with splines. Create a simple circle spline and choose the contour option, so it will create two circles instead of one. Then put it inside your extrude object.
    Mylenium
    [Pour Myl
  • Adam Trachtenberg
    February 13, 2007 at 6:21 pm
    Or, if you want to use polygons, select all of them and use the extrude command with the “caps” option checked. Or to save time, use the tube primitive.
  • Kurt Murphy
    February 13, 2007 at 8:09 pm
    Thank you both….
    kurt murphy
  • Kurt Murphy
    February 14, 2007 at 2:25 pm
    I’ve looked everyehere… Where’s the Contour Option?
    thanks,
    kurt
