Activity Forums Apple Motion Newbie question on templates
  • Newbie question on templates
    Posted by Tom Cavdarovski on May 12, 2005 at 2:47 am
    I’m trying to insert a video clip into a template. I’m dragging the clip into the area where it says ‘replace here’. Result 1) the clip “blocks out” the templates mask and seems to sit on top of everything. Result 2) Alternatively, if I move the clip around into different layers the level of ‘transparency’ seems high and the masking effect almost dissappears. What am I doing wrong?
    TIA
    Mark Spencer replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mark Spencer
    May 13, 2005 at 2:50 am
    You need to make sure you are dragging to the correct object – usually it’s INSIDE the layer called “Replace Here”.
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, Final Cut Pro and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
    https://www.applemotion.net
