Activity Forums VEGAS Pro Newbie Question – Moving Clips On Timeline
  • Newbie Question – Moving Clips On Timeline
    Posted by Henry Panniell on September 22, 2006 at 1:25 pm
    Hello,
    Question 1: I download trial ver or V7 and trying to do a project. The default capture setup at the time was screen detection (I have since changed) this gave me 13 clips total of 54 mins. Editing some of the clips have caused a space between the clips. How do I drag the entire timeline to close the opening, or use a snap-to command to close the opening. Better yet, when I have to edit on the clips and remove some footage, is it possible to make the entire timele snap-to (automaticly) during the process.
    Question 2: Where is the DVD interface or how do I acess it. I did not see it install when V7 installed.
    I have seen a lot of online tutorials that has me up and running, they just have not covered these specific questions. Please don’t go nowhere as i will be back later with another simple newbie question.
    Thanks – Hank
    Asus PC-DL Deluxe, dual3.2 Xeon, ATI Sapphire 9600 Atlantis, onboard sound
    Henry Panniell replied 19 years, 11 months ago 2 Members · 2 Replies
  • Edward Troxel
    September 22, 2006 at 1:30 pm
    1. Multiple ways:
    a. Double click the blank area, press Delete, and then do a ripple edit (i.e. CTRL-Shift-F or you can simply turn rippling on and it will do it automatically)
    b. Right-click the clip to be moved, choose “Select events to end”, and then click and drag it left
    c. Use a script to select all events after the cursor and then click and drag left.
    etc…
    2. DVD Architect is a separate program/separate download. You need to download and install it.
    Edward Troxel
    JETDV Scripts
  • Henry Panniell
    September 22, 2006 at 2:00 pm
    Thanks for the quick reply, I will get to it.
    Thanks again -H
