Activity Forums Apple Final Cut Pro Legacy Newbie Question – Motion Effects
  • Newbie Question – Motion Effects
    Posted by Les Kaye on May 8, 2005 at 5:00 am
    Does anyone know if FCP 5 has the same bug/feature where changing a timeline clip’s fps rate also changes the duration? If so, what’s the workaround – a pre-calculated Fit to Fill?
    Les Kaye replied 21 years, 4 months ago 3 Members · 4 Replies
  • Steve Eisen
    May 8, 2005 at 6:10 am
    It’s not a Bug, it’s simple math. You slow something down, it’s gonna be longer. You speed it up, it’s gonna be shorter.
    There are a couple plug-ins, Twixtor (ReVision FX) and (Boris FX) Optical Flow that can do what you want.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
  • Les Kaye
    May 8, 2005 at 7:17 am
    Um, anyone else?
  • Thaxter Clavemarlton
    May 8, 2005 at 11:59 am
    Its not a bug. Its how FCP works.
    You need to adjust the speed of your clips BEFORE they are edited to the timeline.
    But you can solve this problem afterwards by adjusting the matching “original” clip(s), then editing these newly adjusted clips to replace the one(s) on your timeline.
    On the timeline: Click on the first frame of the clip you want to Slo-Mo or Fast-Mo.
    But do NOT double-click IT into the viewer, but hit the F key so a “match-frame” of the original clip appears in the Viewer.
    Then, adjust the speed of the clip in the Viewer (Cmd-J) to any percent you want.
    Next, on the timeline, use REPLACE to change-out the regular-speed clip with the newly speed-adjusted version.
    Your other clips will all stay in place.
  • Les Kaye
    May 8, 2005 at 12:29 pm
    Thanks much, just what I needed to know.
