Newbie Question – Jumpy Type in AE Animation
I’m using AE 6.5 and have created a “history” sequence for my DVD. I imported old photographs from the Florida Archives and put a colored bar across the title-safe bottom and then typed inside of that. The type doesn’t come in from the sides or anything, it just goes from 0-100 opacity and then back to invisible again. During the time when the type is being displayed, it is “jumpy” (after the entire project is rendered and I play it on my television set) — it looks like a field order problem but i cannot for the life of me figure out how to change the field dominance on something I created in AE… or is it a deinterlace thing? I exported the AE file as a Quicktime with no compression because I brought it into Premiere Pro as a clip and then rendered the Premiere Pro .avi file without compression as well. For some reason I cannot make a DVD from PP (dual-core processor issue), so I bring it into Encore DVD to output the final (and because it requires a menu).
I also made a “credits” sequence and it doesn’t show the same problems at all, same settings.
Thanks y’all
Stacey
