Activity Forums Maxon Cinema 4D Newbie question: how to make polygons from splines
  • Newbie question: how to make polygons from splines
    Posted by Nicholas White on April 29, 2005 at 5:27 pm
    Hello,
    Using CE+ v6…
    I need to make an odd-shaped box.
    I’ve created a sort of a flat square shape using the Draw Bezier Spline tool; this will represent one of two opposing sides of a box. My goal was to duplicate it, offset it on the z-plane by 200m, then ‘merge’ them to create a new polygon.
    1. Is this possible, and with what tools do I use?
    2. Is there a better way to skin this cat? I understand that I could create a cube and pull my shape out, but I’m looking to understand all the program’s features.
    Take care,
    Nick
    Nicholas White replied 21 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 29, 2005 at 5:31 pm
    Create an extrudeNURBS object and drag your spline into it in the Object Manager.
  • Nicholas White
    April 30, 2005 at 12:09 am
    Hey,
    Thanks for you reply. I managed to find another way to do what I needed doing, the problem I had was that when I went to extrude a side, little canyons were appearing in my extrusions where polygon segments were. All I had to do was to make sure that ‘preserve groups’ was checked (I must have unchecked it when playing around with the program).
    Take care,
    Nick
