Activity › Forums › Maxon Cinema 4D › newbie question…. how do you rotate a texture 90 degrees?
  • newbie question…. how do you rotate a texture 90 degrees?
    Posted by Joe Carusoe on July 13, 2005 at 8:10 pm
    i’ve got a cube that i’ve UV mapped a photographic texture onto. problem is, the photo is 90 degrees off. i can rotate the photoshop file, then relink it and it rotates in c4d, but there’s got to be a way to rotate the texture in c4d, right?
    thanks!
    Josh Dekay replied 11 years, 5 months ago 4 Members · 4 Replies
  • Adam Trachtenberg
    July 13, 2005 at 8:17 pm
    You can use a layer shader. Add an effect>transform layer on top of your pic and change the transform angle to 90
  • Nolan Scott
    July 13, 2005 at 9:30 pm
    1. select the polygon you want to change
    2. select cube and Texture-Tag
    3. set projection to cubic
    4. use Texture Tool
    5. Rotate Tool
    Cheers
    Nolan
  • Joe Carusoe
    July 19, 2005 at 3:16 am
    thanks!
  • Josh Dekay
    April 9, 2015 at 11:15 pm
    Thanks for your C4D wizardry!
