Activity Forums Adobe Premiere Pro Newbie Question
  • Newbie Question
    Posted by Randy Curtis jr on June 27, 2015 at 1:53 pm
    Is it possible to transfer a sequence (lets say commercials) from one sequence to another in a totally different file with the adjusted audio & or other settings into another sequence?
    Alex Udell replied 11 years, 2 months ago 4 Members · 4 Replies
  • Mark Whittle
    June 28, 2015 at 7:08 am
    Yes, for example you have an HD sequence, then you can create an SD sequence and place the HD sequence into it, rescaling as necessary. This is nesting essentially.
    Is that what you meant?
    Cheers
    Mark W.
  • Robert Withers
    June 28, 2015 at 5:33 pm
    I sounds like you want a duplicate of a sequence in a different .prproj file. My workaround would be to open a new sequence in the existing file (with the same or different settings), copy the sequence I want into the new one. Delete the original sequence, and save the file with a new name.
    I’m sure there’s a more elegant way that someone with more experience could tell us about.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Randy Curtis jr
    June 29, 2015 at 11:47 am
    Thats exactly what I meant to ask. Thanks for clearing that up for me. So what I meant to ask was..
    If I have a .prproj file named 01 with sequence named “light” where the audio is normalized and cut to a length can I pull it in to a .prproj file named 02 with the sequence named “dark” with those same settings?
  • Alex Udell
    June 29, 2015 at 1:21 pm
    In your new project…
    use the media browser panel and navigate to and open your original project.
    You will see your “light” seq listed as one of the project assets.
    drag it into the new project.
    It’s now an independent safe copy of your sequence.
    Rename and work away…
    hth,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
