newbie question
Posted by Brian on June 29, 2006 at 7:54 amI’m trying to learn vegas. when I capture in vegas 6 all I’m apparently able to capture is the audio, no video appears in the video track timeline.
What are some likely culprits? I’m hoping something obvious.
Richter12x2 replied 20 years, 2 months ago 3 Members · 6 Replies -
Edward Troxel
June 29, 2006 at 1:10 pm -
Brian
June 29, 2006 at 9:57 pmI’ve been going to file then capture video with firewire to a sony trv900.
Edward Troxel
June 30, 2006 at 2:29 am -
Brian
June 30, 2006 at 2:56 amSo why am I only getting the audio track? I don’t have this issue with
edius on the same computer, with the same camera. -
Edward Troxel
June 30, 2006 at 1:41 pmAre you getting a standard DV-AVI file? Are you capturing via firewire? And you are using the External capture?
All I can tell you is what I know about Vegas VidCap. When capturing via firewire, it will capture to a standard DV-AVI file. It does not have a means of capturing audio only. In fact, people that want to do that frequently use Scenalyzer Live.
You might also try Scenalyzer Live to capture. Many people using Vegas use it for capturing instead of VidCap. (Personally, I use both – each for different reasons).
Richter12x2
July 24, 2006 at 7:10 pmJust a thought, but for some reason when I capture in Vegas, I know I have to select the device on the Capture window before it will talk to the camera. Then is it a DV camera? Maybe there’s some kind of video codec in use that Vegas doesn’t support, but the audio is a regular PCM, something like a special HDV transport in an earlier part of Vegas?
