Activity › Forums › DaVinci Resolve › Newbie Q, how do I replace footage with VFX clips
Posted by Itai Bachar on August 21, 2013 at 1:41 pmHi all
New to Resolve,
Ive conformed an AAF of a 4 minute movie, and there’s now shots that are coming from NUKE & AE that I need to replace.
Normally, in Flame, I would copy the conformed clip, call it Master and start updating this new timeline, not disturbing the original conform.
(this way I have the original Edit in tact for going back if I need to)
How can I copy the timeline in Resolve?
Or is there a better strategy of building up the work?
ItaiItai Bachar replied 13 years ago 4 Members · 8 Replies -
Laco Gaal
August 21, 2013 at 4:04 pmhi,
newbie questions usually go here: https://forums.creativecow.net/davinci_lite
My way for doing this is simply add a new video track, and keep the original video at track 1 (in case of you need to export it to somebody), and put the VFX shot at track 2. After that you can simply copy the grade to the VFX shot.
Itai Bachar
August 21, 2013 at 4:23 pmThanks, but there’s a lot of dissolves which I don’t want to recreate.
I need the same conform copied so I can insert new clips into it. -
Sascha Haber
August 21, 2013 at 7:43 pmThe easiest and most painless way to to this is to use Scratch…
Just kidding..;)
What we did is to have an intermediate stage where you will overwrite the footage.
So you should make a copy of your footage folder now and rename that GRADED.
Then you ask the VFX guys to overwrite the footage in your other folder whenever they see it fit for judgement.
Depending on the need of having to go back to old versions you can make the data wrangling process with scripts that automatically move the last version into a folder with a new version.
So you are always looking at the most recent VFX with the ability to manually load the last one or any you need to compare.
Use a new video track for that, its easiest like that.Good luck 🙂
A slice of color…
Resolve 9.1.4 , Smoke 2013 EXT
Colorist / VFX / Aerial footage nerd
https://vimeo.com/saschahaber -
Itai Bachar
August 21, 2013 at 8:28 pmThanks, but the source footage is comprised of 300 gb of Epic and Alexa clips.
How can you accomplish overriding those with VFX shots done at HD with file sequences?
Sigh… there is really no way to duplicate a timeline, not the entire footage?
Seems I will need to re-conform it with a different name.
Only thing that I had some problems in the Conform and I don’t want to go over that again…
How easy is Scratch to learn? 🙂
Itai -
Laco Gaal
August 21, 2013 at 10:17 pmif you want to simply duplicate a timeline, select all the clips, copy, and paste it to a new timeline?
Itai Bachar
August 22, 2013 at 1:52 pmAfter a few crashes, Resolve allowed me to copy and paste the tracks, thanks!
Now I have another newbie question but I’ll post it in the Basic forum,
Thanks -
Paul Provost
August 22, 2013 at 4:16 pmCopying and pasting into new track will not bring over resizes in aaf.
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Twitter 4kfinish
