Activity Forums Maxon Cinema 4D Newbie Q for aspect Ratio
  • Newbie Q for aspect Ratio
    Posted by Nate Tull on October 2, 2009 at 8:35 pm
    OK this is gonna be SO Busch league but here it goes…. I opened up my render settings & set the resolution to 1024×768, file format to the same. In the Perspective view I have my title safes up…..what I need is to be working in 16:9 but its still 720×480 where do I set things so Im working in 16:9? thnx
    N8Pro1
    Nate Tull replied 16 years, 11 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    October 3, 2009 at 12:00 am
    Why did you set the render settings to 1024 x 768 when you want to work in 720 x 480?
  • Nate Tull
    October 3, 2009 at 12:55 am
    No i want it to be 16:9
    N8Pro1
  • Adam Trachtenberg
    October 3, 2009 at 3:49 pm
    If you go into the render>output settings, under “film”, there are presets for pretty much any format you might want. If none of those work for you you can type the exact dimensions into the width/height settings. In other words, those width/height settings are what determine the output size and the masked area in the editor, so if you don’t want 1024×768, don’t type 1024×768 in there.
  • Adam Trachtenberg
    October 3, 2009 at 3:53 pm
    Also, if you set “Film Aspect” to 16:9, Cinema will automatically calculate the correct height based upon the width that you enter.
  • Nate Tull
    October 3, 2009 at 4:12 pm
    thank you so much
    N8Pro1
