Activity Forums Adobe Photoshop Newbie Problems
  • Newbie Problems
    Posted by Cut-splice on March 22, 2007 at 11:51 am
    HELP!!
    OK I think I really screwed something up now.
    I was having problems opening up an .eps file in my photoshop 4.0 LE so I installed photoshop 7.0
    (I sent the eps file to a friend and he said he had no problem opening the file in PS7)
    I continued to have a problem as a message stating something about “Rasterize”? continued to pop-up. I read this had something to do with layering…
    I surmised the problem might be that I had both versions of photoshoop installed on my computer and that the 4.0 LE edition might be interfering with the PS7 edition.
    I transferred the 4.0 LE to an external hardrive
    After I transferred the file I completely removed the
    program from my ‘Program’ file. (I think I removed
    something in Adobe that I needed.)
    NOW THERE IS SOMETHING MISSING ON MY COMPUTER..
    1) When I try to open the logo (.eps file) there is no
    longer a ‘Run’ option, now it says ‘Find’
    When I click this menu it takes me to an Adobe website
    and prompts me to purchase photoshop.
    2) When I try to open Photoshop 7.0 on my computer a
    menu comes up stating “could not complete your request
    because of missing or invalid personalization
    information” ???
    3) When I try to re-install photoshop 4.0 LE I
    continue to get a message stating “the item that this
    shortcut refers to has been changed or moved, so this
    shortcut will no longer work properly.”
    I’m stuck!
    Cut
    Scimmy replied 19 years, 4 months ago 3 Members · 4 Replies
  • Tiffanib
    March 23, 2007 at 2:18 pm
    Reinstall version 7.
    Never remove a program by just “moving” it elsewhere. You need to go through the system’s “Add/Remove” feature and remove it that way.
    Tiffani B
  • Cut-splice
    March 26, 2007 at 2:09 pm
    Tiffani,
    Thanks for your reply. I am now back up and running with photoshop 7. However, I am still stuck with my original problem:
    I am trying to open an .eps file When I click ‘run’ I get a menu in photoshop titled ‘Rasterize Generic EPS Format’ If I click OK I get a message stating photoshop could not open the file because the parser module cannot parse the file?
    Any help and/or leads where to find information on rasterize and parse would be greatly appreciated.
    Thanks again,
    Cut
    PS I plan to re-post this message under a new heading as well.
  • Tiffanib
    March 26, 2007 at 6:05 pm
    It sounds like the file is corrupted. Can you delete it, and replace it with a new one? Have the person who created it open it on their machine and resave it, then send it to you to try.
    Tiffani B
  • Scimmy
    May 4, 2007 at 1:51 am
    Yo Cut, You can’t “open” a .eps in P-Shop without it rasterizing. To use it as a vector file in P-Shop do the following:
    1. Create a new PS doc, set dimensions according to final output.
    2. In “File” pulldown menu, select “Place”: navigate to and select/place the desired .eps file.
    3. The file will appear on a new layer with a rectangular bounding box around it. You can scale the .eps without degradation at this point by grabbing a corner. Note that to retain original aspect ratio you must hold down shift key WHILE scaling.
    4. After size is set, hit enter key to rasterize file and set it into layer. Any scaling of layer now will produce artifacting.
    An eps file can be manipulated in After Effects without rasterizing, which is nice.
    Good luck. Scimmy
