Activity Forums Maxon Cinema 4D newbie nurb question
  • newbie nurb question
    Posted by Scyld on March 1, 2011 at 3:54 pm
    hi, i’m slowly teaching myself C4D and i’m having a few problems trying to create a section of a sphere, like an orange slice. i’m using this piece for reference:
    https://vimeo.com/18717402
    i’ve tried the GSG tutorial with an arc and lathe nurb but i can’t get it to work… if anyone can give me some tips on how to model an ‘orange section’, or point me to a tutorial that would be great. many thanks in advance!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Scyld replied 15 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 1, 2011 at 5:32 pm
    Lathe nurbs is the most flexible way to do it:
    Create an arc spline and set the end angle to 180;
    With the arc selected, in the attributes manager and select the “Coord.” tab;
    Type 90 in the R.B (rotation>bank) box;
    Create a lathe nurb object and drag the arc spline onto it in the attributes manager. That makes the arc a child of the lathe nurbs and it should already give you a sphere section;
    With the lathe nurbs object selected, adjust its Angle parameter in the attributes manager to change the size of the sphere section.
  • Scyld
    March 1, 2011 at 5:38 pm
    perfect! many thanks adam.
