Activity Forums Apple Final Cut Pro Legacy Newbie needs workflow for AVCHD files with Separate Audio in FCP7
  • Newbie needs workflow for AVCHD files with Separate Audio in FCP7
    Posted by Josh Daniels on April 17, 2014 at 7:26 pm
    I’ve been struggling for a few days with this and I’m pretty sure that my receding hairline has receded even more as a result.
    I have a 4 camera project – a concert with approximately 1 hour of continuous shooting for each camera. The audio is a separate mix of the show.
    The cameras are mt2s at 59.94 fps with audio at 44.1. The separate mix is is 44.1 as well. I would like to sync all 4 cameras with the audio and make a multiclip of the show. What would be a smart way to go about this?
    Josh
    Josh Daniels replied 12 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 17, 2014 at 7:44 pm
    First off, convert all the audio to 48Khz. FCP doesn’t sync properly with 44.1Khz. Not sure how a camera comes to record audio at 44.1K…all the ones I know record at 48K.
    Shane
    Little Frog Post
  • Josh Daniels
    April 18, 2014 at 4:08 pm
    Thanks – yes, you are correct. The original MT2Ss have 48K. I asked for a 48K WAV mixdown of the audio track and got one. I tried to convert to the Intermediate Codec and sync via in-points.
    I can get sync on all of the video in a multiclip, but the audio track is way way off – by minutes, even when I select the same in point.
