Activity › Forums › Apple Final Cut Pro Legacy › NEWBIE NEEDS ADVICE
  • NEWBIE NEEDS ADVICE
    Posted by Rtv Edit on July 6, 2005 at 11:49 am
    this is probably going to draw some laughs but i gotta ask. i am a new user of fcp 5.0 though i have edited before most the material went to the web so i didn’t learn to PRINT or EDIT to tape.
    here’s my set up
    G5 D2 HARD EXTREME 2.8 DUAL with 1 GIG of RAM RUNNING TIGER 10.4
    3 LaCie drives 250 each in a firewire 800 daisychain
    FCP 5.0
    SONY DSR-11
    TWO VISTA LINE 17 inch monitors
    So I have a sequence built as DVPAL and I am tryin to EDIT TO TAPE. My settings are standard DVPAL all the way capture, sequence etc. So when i try to edit to tape. mirror to desktop is selected.
    each time i EDIT to TAPE…there’s no signal to the tape deck. on the actual tape when i play back is just gray not black but gray
    so i try to PRINT to TAPE…i get about 5 minutes through my sequence then i get a dropped frames abort message.
    is this a fire wire 400 to 800 thing?
    confused and needing help
    thanks
    Rtv Edit replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
