Newbie Library Size Question
I’m trying to create a wedding documentary project as a surprise for my wife and am putting interview clips into the small amount of wedding day footage we have. The issue I have is that the library is on an external hard drive so she doesn’t find it and its already huge! I need to get a few more interviews done so will need to store the footage, and am trying to edit the bits that I have together to allow as much time as possible to get everything done, but the library file is now 269GB and I don’t have much hard drive space left.
I’ve created some multicam shots and synced audio in from an external source so I know it will be a large file anyway, but every time I make an edit or change a setting it seems that it just chews up whatever space I have left. Is there any way to reduce project size? I’ve deleted the render files and that created 20GB, but obviously when I started editing again FCP started to re-render everything so I lost the space.
The project is probably going to end up being 30-45 mins long when it’s done (currently at about 23 mins), so roughly how much hard drive space do I need, how can I minimise the amount of space the project takes up and is there an easy and quick way of setting this up?
Pete
