Activity Forums Adobe Premiere Pro Newbie importing question
  • Newbie importing question
    Posted by Nick Ardner on March 20, 2017 at 7:25 pm
    Hello, I shoot my footage in 4k. When I am working with my clips, they are huge and can cause some sluggishness with my PC from time to time. Is there a way I can do something with the clips upon import to reduce them from 4k to something else that is smaller and easier to work with and then reverse what I initially did so I can export in high quality? Open to any suggestions!
    Nick
    Michael Foster replied 9 years, 6 months ago 2 Members · 1 Reply
  • Michael Foster
    March 20, 2017 at 7:46 pm
    First, you can playback your video in 1/2 1/4 1/8 resolution in the composition window. There should be a little button on the bottom right of the player window.
    Second, you can take full advantage of adobe media encoder. Using Adobe native codecs, although front-end intensive will help.
    Third, make sure that Adobe Premiere has full access to a solid allocated amount of RAM.
    Fourth. Take advantage of proxy-files for large projects.
    I’m not going to go into full detail for each because there’s plenty of youtube videos for all 4 of these! ☺ Good luck!
    -Foster
