Activity › Forums › Compression Techniques › newbie cleaner question
  • newbie cleaner question
    Posted by Sidewalksurfing on January 6, 2006 at 6:52 pm
    hi everyone
    just purchased cleaner XL to compress 320×240 QTs to FLV files to play on our website. they are :30 sec spots. i have been having trouble finding that perfect balance of quality & smooth playback speed – right now they look super choppy on our site and i’m reluctanct to decrease the quality even more. I have been doing some research on this board and it seems like there are some other apps that people really like… have i chosen the wrong program to do my compressing? i thought cleaner was supposed to be the premier package.
    i have definetly seen good compression at this size & length on other websites – help!
    thanks for any info
    tim
    Charles Simonson replied 20 years, 8 months ago 3 Members · 2 Replies
  • Rich Rubasch
    January 7, 2006 at 4:13 am
    First, when you say 3230 x 240 QT movies, what codec are the quicktime movies now? Feeding the highest quality source file to the encoder will result in the best result. Are your QT movies interlaced, or did they originate from interlaced sources (videotape)? What frame rate are the QT movies and what frame rate are you using for the FLVs? What bitrate settings are you using?
    Rich Rubasch
    Tilt Media
  • Charles Simonson
    January 9, 2006 at 1:14 am
    For Flash video encoding, Squeeze is generally considered the best. Also, there is the new On2 codec for FLV encoding that many of the higher end sites are using, and it is a separate purchase from either Cleaner or Squeeze (but should integrate into both). The On2 codec will give you the best possible quality, but the standard encoder in Squeeze is also quite good. And, if you have a higher, full-res source to use, that would help increase end result quality.
