Activity Forums Maxon Cinema 4D Newbie: Can an object be made to conform to a spline?
  • Newbie: Can an object be made to conform to a spline?
    Posted by Dave Edwards on August 8, 2010 at 5:59 pm
    I have a long, thin object, like a rail: I would like this to conform to a spline. When I try to use the BEND tool my object distorts. Is there a way of having such an object follow the shape of a spline?
    Dave Edwards replied 16 years ago 3 Members · 3 Replies
  • Adam Trachtenberg
    August 8, 2010 at 11:40 pm
    Check the “path deformation in 11.5” thread below.
  • Gon Perdigao
    August 9, 2010 at 9:00 am
    why don’t you use the spline wrap, of the moograph module?
    Just make your spline, and then drag the spline wrap, under the object and say what spline is it, and you must better control
  • Dave Edwards
    August 11, 2010 at 12:44 pm
    Thank you both,- problem solved!
