Activity Forums Maxon Cinema 4D newbie c4d :-\ text issue
  • newbie c4d :-\ text issue
    Posted by Kutterup on June 25, 2005 at 3:55 am
    i would like to know if any one here could tell me how to add text to an object.
    i did some text in photoshop, imported it into c4d, and loaded it as a texture. the object just turned black.
    so tell me how do i add text??
    Colinmcd replied 21 years, 2 months ago 2 Members · 1 Reply
  • Colinmcd
    June 25, 2005 at 9:56 am
    You should try loading your text ‘texture’ into the Luminance channel of the shaders menu.
    If it’s coloured text and you want to layer it onto a different coloured background of your object, try using your text in the Alpha channel of the shader options. Just do a white text on a black background in Photoshop – you can invert the Alpha within Cinema if you get it the wrong way round (as I frequently do!)
    Cheers,
    C
