Activity Forums DVD Authoring Newbie Authoring Event 3day Footage
  • Newbie Authoring Event 3day Footage
    Posted by Praveen Rp on April 25, 2009 at 11:55 pm
    Im working on my first project coming up for a small college graduation, clients wants me to record 3 events. I’ll be using GL2’s
    1st Event roughly 2 hours
    2nd Event is 2hours
    3Event 2.5
    Close to 7hours total of footage
    With my limited knowledge of bitrates and compression, is it feasible to create a quality dvd for packaging & selling with all 3 events on 1 disc?
    I just have a MacBook Pro with FCP Studio, I think compressing all that would just eat my machine time for days.
    Should I just edit down each event separately then go to a duplication studio and have them master it?
    Comments & Suggestions greatly appreciated
    Matt Townley replied 17 years, 4 months ago 4 Members · 3 Replies
  • Eric Pautsch
    April 26, 2009 at 2:36 am
    The most I ever got onto a dual layer disc with reasonable quality was 5 hours – and this was with an encoder which cost thousands of dollars and a extremely clean source. This will have to be a 2 disc set for sure.
  • Michael Sacci
    April 26, 2009 at 4:55 am
    I would go to a 3 disc set if you are duplicating these. (3) DVD-Rs are cheaper than (1) DVD+R DL, The case may balance out the cost but it will seem like more of a value, quality will be better. Remember even 2-2.5 hours on a disc is pushing quality, footage from GL2 tends to be grainy.
    Remember a DVD DL is not equal to (2) DVD-Rs, it is less. 8.5GB vs 9.4GB. Edit anything you can out of these, most things can be tightened up quite a bit.
    Here is the break down on Bitrates if you use ac3 audio.
    3.8 Mbps – 270 minutes on a DVD-9
    4.3 Mbps – 240 minutes on a DVD-9
    4.8 Mbps – 120 minutes on a DVD-5
    3.8 Mbps – 150 minutes on a DVD-5
    tough to get a very clean encode with compressor at 3.8 Mbps unless you are work with perfectly exposed Dbeta, and even at that it is pushing it.
  • Matt Townley
    April 27, 2009 at 2:45 pm
    I agree with Michael. Go with a 3-disc “box set.” This will keep your video at a higher quality and add perceived value to the people buying it. You may be able to charge more since there are 3 discs instead of “just one.”
    If you need duplication for your project when you are done, feel free to email me and I can give you a quote.
