Activity › Forums › Adobe After Effects Expressions › newbe wants a simple explanation
  • newbe wants a simple explanation
    Posted by Dan Blaim on February 5, 2007 at 6:56 pm
    I have a very limited knowledge of expressions and wanted an explanation of what the numbers mean in the following expression.
    wiggle(3,90,1,1,10+time). I have used wiggle(3,90) in the past with good results. I just wanted to know what the extra 1,1,10+time do.
    Thanks.
    Dan Ebberts
    replied 19 years, 7 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    February 5, 2007 at 10:20 pm
    The wiggle parameters are (in this order):
    frequency = wiggles per second.
    amplitude = amount of wiggle.
    octaves = number of octaves of noise to add together – the more octaves, the more complex the wiggle.
    amplitude multiplier = how much the amplitude is multiplied for each successive octave.
    time = base start time – defines where (in time) the animated property is sampled.
    The best thing to do is play around with the parameters and get a feel for what they do.
    Dan
  • Dan Blaim
    February 7, 2007 at 3:24 pm
    Thanks for the explaination. I will take your advice and play around with the settings. Thanks for taking some of the guesswork out of it.
    Dan
  • Dan Ebberts
    February 7, 2007 at 3:30 pm
    I’d suggest applying a wiggle expression to a slider control and then turning on the graph in the timeline so you can see effect of changing each parameter.
    Dan
