Activity Forums Adobe Illustrator Newb Illustrator fill question
  • Newb Illustrator fill question
    Posted by Nancy L. sutton smith on November 5, 2011 at 12:49 pm
    I traced a coffee mug with the pen tool. Then I traced the inside of the mug handle, creating two paths. I want to fill the mug but not the inside of the handle. No matter what I do – arrange the handle path forward – non zero – compound path – all the suggestions on the internet – filling the mug, fills the handle path. How do I make the inside of the mug handle no-fill?
    Nancy L. Smith
    President
    Sutton Bay Media Company
    Nancy L. sutton smith replied 14 years, 7 months ago 2 Members · 2 Replies
  • Vincent Rosati
    November 5, 2011 at 4:50 pm
    Maybe first try practicing creating a compound path with simpler paths.
    Use the Ellipse Tool, select a fill color, draw one big circle, then draw a smaller circle inside it.
    Next, use the Selection Tool to select both of the circles.
    With both circles selected, click Object / Compound Path / Make.
    At this point, you should now have a compound path.
    The next step would be to determine why your objects won’t become compound paths.
    It’s hard to say what the issue might be.
    Another approach you might want to take would be to layer the inner/negative/inner handle shape underneath the primary/outer/mug shape and do Pathfinder/Minus Back.
    Here’s an example file
    Compound Path and Pathfinder Minus Back
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Nancy L. sutton smith
    November 5, 2011 at 8:01 pm
    Thank you! You were exactly right! I appreciate the attachment so much.
    Nancy L. Smith
    President
