Activity Forums Apple Final Cut Pro Legacy new user QU..
  • Posted by Romy Marx on February 4, 2008 at 10:47 am
    last two days i began to use FCP but i found it has something strange! and asked friend who use it long time ago he told me there is no solve for it!
    When i edit in clip on time line and want to speed the first part of it..
    i find all time line comes rippled with the same duration the clip decreased with!!
    can anyone help me telling me how to fix this??
    thanks
    Romy
    Jerry Hofmann replied 18 years, 7 months ago 4 Members · 4 Replies
  • Walter Biscardi
    February 4, 2008 at 11:39 am
    [romy marx] “When i edit in clip on time line and want to speed the first part of it..
    i find all time line comes rippled with the same duration the clip decreased with!!”
    Yes, this is one of the failings of final cut pro. when you change the speed of a clip, it pulls or pushes everything else in the timeline. It should not do this, but that’s how it’s designed to work.
    The way we work around this is to put the clips into a different timeline, change the speed, then bring the clip into the main timeline.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Romy Marx
    February 4, 2008 at 12:58 pm
    thank you..
    i do semi as u do..i speed my clip at end of timeline..then cut and paste at place i want!..
    another 2 tricks plz..
    1-when i drag and drop clip into timeline..it usually shift next clips when small black arrow point to next….and overwrite when it point at down..
    SO i want all files i drag and drop to b in over write mode..
    is their option where i can disable the shifting option??
    2-when i copy and paste piece of clip at time line ..how can i paste it to another layer than the one i copied from??
    thank you very much!
    ROMY
  • Jeremy Garchow
    February 4, 2008 at 4:09 pm
  • Jerry Hofmann
    February 4, 2008 at 8:00 pm
    I think the best way to perform speed changes in FCP is to match frame the “source file” command is found in the Match frame submenu… change the speed of that clip in the Viewer, then edit it in… Doesn’t change the speed of the clip already in the sequence, and doesn’t change the speed in the browser clip either.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
