Activity › Forums › Adobe After Effects › new Twixtor broken?
new Twixtor broken?
Posted by Pierre St-jacques on September 29, 2015 at 4:44 pmThis morning I downloaded the new Twixtor 6.2.2 and after installation nothing seems to work with it. All I get is a still image…
On a Mac Pro running 10.10.5 using Premiere Pro cc2015. Will keep tinkering but I was wondering if anyone else is experiencing this?Peter Litwinowicz replied 11 years ago 3 Members · 4 Replies -
Pierre Jasmin
September 29, 2015 at 6:32 pmCan you confirm if this is Premiere 9.0.2?
Did you apply Pro or Regular version?Perhaps ping us at tech support @ revisionfx dot com
so we can follow-upPierre
Pierre St-jacques
September 29, 2015 at 8:16 pmAfter more tinkering this afternoon I’m realizing that my problem – twixtor not working / only getting a still image – occurs when the speed is set to a negative value, otherwise things seem to work fine.
I’m using the regular version of Twixtor on the latest Premiere Pro – I can’t check the number – but I will! – as I’m away from that computer at the moment…
Pierre Jasmin
September 30, 2015 at 12:48 amYes negative value goes backward, so that only works from a point in clip – as on second frame otherwise you are already out of range
Pierre
Peter Litwinowicz
September 30, 2015 at 12:59 amTo add to what Pierre said, from the manual:
Note on negative speed: A Speed% of -100.00 does not simply flip the original sequence so that it plays backwards starting at frame 0. Imagine the play head on your clip. If you are at the beginning of the clip and you tell the machine (Twixtor in this case) to start playing backward, then there’s nothing before the clip starting position to play. That’s why you will not see a result with a negative speed as the first keyframe. If you play the clip at 100% for a while, then put in a –30% keyframe (or other negative value) at the place where you want to start playing backward you will see proper results.
Pete Litwinowicz
