Activity › Forums › Apple Motion › New tutorial on lightwraps
  • Jeremy Garchow
    August 2, 2006 at 3:16 am
    Pretty cool, man. The only problem I see is that in your tutorial you say to apply the color correction to the beach layer, when in reality it should be applied to the hand layer.
    Jeremy
  • Doyle Rockwell
    August 2, 2006 at 3:40 am
    Doh! Thanks for spotting this. Once again, paste-bombs strike at 2 a.m. Fixed that.
  • Jeremy Garchow
    August 2, 2006 at 3:46 am
    Otherwise, it’s a cool tutorial. I have a big green screen project that I am in the process of posting, and this might come in handy.
    Jeremy
  • Winston A. cely
    August 4, 2006 at 9:25 pm
    What if you’re subject is moving from one side of the screen to the next? Will those masks still work with moving footage?
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
  • Doyle Rockwell
    August 4, 2006 at 10:22 pm
    Heya,
    Because the masks are Image Masks and are based on the alpha of the foreground element, they will always fit. So, if you had some text flying across, or an actor walking, etc, it would just work.
  • Winston A. cely
    August 4, 2006 at 10:52 pm
    What a stupid question I just asked! Sorry about that guys.
    Anyway, I just ran through the tutorial with stock footage. Wow, does a great job, but the stock footage is so nappy, that it still doesn’t give a very good key. BUT having used your steps, it’s a lot better than it would have been.
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    Memory: 4.5 GB
