Activity Forums Adobe After Effects “new tracks were created for each device”
  • “new tracks were created for each device”
    Posted by Joshua Guerci on February 8, 2017 at 1:12 am
    I’m using PluralEyes 4.1.1 and I am trying to sync footage from my C100 with audio from H6N. I import everything just fine but when I go to sync it says “”4 tracks contain clips from several devices, new tracks were created for each device” and then creates a separate track for each clip. Its fine if I’m only syncing 2-3 audio clips but if I’m syncing 50 audio clips such as from a narrative shoot, its disastrous! Any ideas? Do I need to upgrade my PluralEyes?
    http://www.filmless.com
    Urten Ekran replied 9 years, 5 months ago 3 Members · 2 Replies
  • Kevin Carlson
    February 14, 2017 at 2:47 pm
    I think you can disable its ability to create new tracks can’t you?
    I’ve had so many tickets with them about v4 it’s ridiculous, but I think they are working on the bugs and have been responsive.
  • Urten Ekran
    April 5, 2017 at 10:45 pm
    I have the same issue but I figured out a workaround:
    Put all your files in a timeline in Premiere Pro (maybe this also works with other NLE) and save it as a xml. Then import the xml into Plurleyes and sync.
    Or just use Pluraleyes 3
