Activity Forums Maxon Cinema 4D New to xpresso
  • New to xpresso
    Posted by Olly Bea on August 6, 2009 at 8:26 am
    Hey all, I am new to xpresso, and I am sure what I am trying to achieve is simple I just don’t know how.
    I have 2 helixes and I want to work it so that when I change the height of the main helix the secondary helix matches it. I think I have worked out the first bit… I have dragged both helixes into the xpresso window and setup the object property ‘height’ in and out ports on each, but I am not sure which node I need to select to do what I am trying to achieve.
    Also, apart from Cinema 4d’s help (which ironically isn’t much help) is there anywhere that explains the different nodes in a simple way?
    Any help is greatly appreciated.
    Olly
    Olly Bea replied 17 years ago 2 Members · 3 Replies
  • Randy Johnson
    August 6, 2009 at 12:44 pm
    You dont need any more nodes.
    If they are plugged in like the attached pic. You can animate them both with the A1 height control.
    /Randy
  • Randy Johnson
    August 6, 2009 at 12:45 pm
    /Randy
  • Olly Bea
    August 6, 2009 at 1:51 pm
    Superb thanks very much. I knew it was easy
